Shock Mounts
IIRC you need another triangle shaped bracket for the other side of the 2nd shock (I have a set), shock spacers (I have a set) and I believe just a longer bolt and washer for the axle side. Don't recall for certain on the axle set up. They put the shocks on the sides of the axle tubes to try and combat axle wrap.
