shocks for a lifted k5
newk5driver
Owosso MI
Does anyone know if there are stock shocks on a different vehicle that would fit a 1986 k5 blazer lifted 4 inches?
For the front, do a search for the Ford shock tower conversion. I am not sure of the specifics, but that might work out.
For the rear... well I'm not sure. I remember back in the day I purchased Skyjacker hydros for about $25 a piece. They worked OK.
Clay
99-up ford 250-350 stock length fronts are a bolt in just add the steel sleve to the upper mount eye . i will post the link later . its saved on my home computer.
i just did this . on my k30 with 3"hd . there is a old thread here on ck5 on ford shocks bolt in . there is a rear also just dont recall it . as i did stock rear with new shock tabs welded in a more upright position .
give me till around 12-1pm and i will be home to post up the link someone here made a thread on . there monroe shocks also if you wana search a bit first.
but front is a basic bolt in . just need to 2sleeves from aftermarket shocks to make the rubber bushing reduce down to the bolt size.
i got my 2 fronts from a excursion i did a lift on for a guy and the shocks were like new . so i didnt toss them out .
