I currently have 220lb/in springs on the front of my 72k5. I have bilstein 5150s in the heavier 255/70 valving. The shocks seem to be wayy to stiff for the truck. When I hit a bump on the road, even a small one, the whole truck drops in the hole. Would I be better with softer shock valving?
I was thinking of going f-o-a emulsion shocks so I can adjust them. Would the 2.0 be sufficient, or should I go for the 2.5? I do a little bit of slow wheeling, and some beach driving, but mostly street.
To understand how a suspension works with the shock, you have the curves from the road, and the shock brings the peaks of the curves closer to the middle line, if that is what you are feeling then its good.
