well Friday I went and picked up the other air compressor I purchased for the electric motor it had on it .
got a nice tank looks to be about 60 gal . guess I will add this in to the system for a 200 gal storage total .
the pump unit is a older IR t30 style model 234 looks to be 9cfm @ 175psi in the 3hp motor spec it would of had way back in the day . I am going to spin it with the old motor off my 2 stage and just get the correct pulley size to match the rpm . this will be a backup unit or what ever little jobs I would need it for .
next I setup both units to get a idea on layout . I think its tight but it would be so easy to just do a pair of new top plates to bolt down to these a hair bigger . this will also give me the chance to add in rubber for anti vibration between the plate and tank top plate .
funny thing . . . both magnetek motors . . . . old one is physically smaller than new . . . old draws 22 amps on spec tag . . . new BIGGER motor draws 20 amp
for now here is the stuff . . .
mounting bolts off flush with the floor .
. . . but turn by hand bench test pin pointed the problem why it was so hot / wouldn't get over 120psi the blow by in to the crank case was so bad it was almost ready to pop the filter out of the vent / fill port .
........ so glad I didn't waste money on parts for that pump .
and I open it to find no extra beefy anti blow threw packing . just 1 wrap of tiny bubbles wrap on 1 then other set on top and the shipping air filled bags and all of them popped ! ! !
