and new adaptor to the tranny and new input gear to the tcase or swap to a special output shaft back down to 27 spline. the th400 uses a 32 spline shaft. also you will need the vac line for the modulator. then the gas pedal switch and wire from the fuse box to the switch to the firewall hole and down to the tranny for the kickdown.
