I'm having an issue with the pulley alignment of the alternator on my 67 Elcamino.
It has what I believe to be the "correct" upper and lower alternator mounting brackets for the year. Has the short water pump. Has the 3 groove crank pulley and the outer groove aligns properly with the power steering pump. Alternator belt is on the inner crank pulley groove, which aligns with the inner water pump pulley groove, but the alternator pulley is 1/4" back from being aligned with them.
I used a straight edge to verify the measurement. Pulled the alternator and took it to Napa and verified it's the right part. Looked around online and the brackets I have cross to the right applications.
Short of custom spacing the pulley out, I don't know where to go with this.
Anyone have any ideas?
