BUDDYRAMMIT said:
i like what youve done here. i want to use a bed from a k10, do you think the front body mounts for the long bed and the short bed are in the same location? in this case all i would have to do is add rear body mounts for the short bed? also, would the stock gas tank still work in this situation?
I do not think you could just slide a short bed forward (the arch of the frame would conflict with the crossmembers of the bed).
Im building a short bed crewcab.
I havent cut the frame down yet.
I plan on taking a section out right behind the cab & then also a short section at the rear.
The bed is bolted on with 8 bolts, 4 on each side.
Looking from the cab to the tailgate the 2nd row & 3 row of bed mounts line up for both short & long beds.
It centers the wheel well over the tires.
I will use the 1st row bed holes to lineup with the frame holes to get the factory spacing between the cab & bed.
Hard to explain but easy to see when under the truck.
As for gas tanks you would have to use ones for a short bed (16 gal).
The frt spring hanger for the rear springs would be in the way of the long bed tanks (20 gal).
Let me know if I can help with any other questions.
