Got some stuff done. I was going to put it all together to get it in, and move the tank when I do the shortening. But I figured I'd get as much done now as I can.
So I moved my shocks to get the tank far enough forward that I can just lop 4" off the end of the frame when the time comes.
I built some shock mounts out of some scrap and leftovers we had around.
I realized that it'll have to be cut out to ever be removed, but I'll flange it if that time ever comes.
Both of them on the front of the axle probably isn't ideal. But to get that tank in there I didn't have much choice.
The rear cross member was de-riveted. And bolted back in for now. It will move forward 4"-5". I also cut and drilled the angle iron that will be my front tank strap mount.
When I in hooked the shocks I realized that the factory mounts only gave me about 2" of droop
. They're 11" travel shocks.
So I measured the amount of up travel I would have if sitting hard on compressed bump stops, and gave them 1" of extra room. Then mounted them accordingly. Now I'll have the ability to smack the stops without hurting the shock, and have about 6" of droop available.
Shock bolts are now 5/8".
