I recently put 4.10 gears in the Blazer. previous gears were 3.08. I am running 35 x15 tires. the truck seems like it is giving all its got to go 65. I do not have an rpm gauge but it sounds like its giving all its got. The last shift point I hear is when my speedo reads 50. By my calculations in truth I am going 40mph at this point. when my speedo reads 60 to 65 it seems to be wound up tight almost like it needs to shift one more time and it would be ok.
Is there an adjustment that I should have done to the shift points or is this what is correct and I need an over drive if i want to use the interstate?
