Silly Hydroboost fluid question of the day!!!
Xtremjeepn
Saddle Rock, CO
What fluid do you run in it?
Here is the basis for the question. I just took the pump out of this truck I am building and it was full of brake fluid, not power steering fluid. :confused:
Just got a new pump. What is the best fluid to run?
Uhh, brake fluid in the power steering system? Mighta been some kind of generic hydraulic fluid.
or your PO was a dork. ;)
Should be PS build, or maybe ATF, in the PS system, including the hydroboost pump and booster proper.
Obviously the master cylinder should have brake fluid in it.
-- A
I run PS Fluid in mine. Brae Fluid can eat the seals in the pump and there are arguments over running ATF due to moisture concerns.
I dont know any of it and since it comes from the PS pump I run PS Fluid.
Ira
That's what I thought. Probably explains why the pump was leaking the way it was. Got a whole new unit with resvoir. Thanks guys.
I use Valvoline's synthetic p/s fluid. I've read that the GM brand fluid is the best, but it's freakin' outrageously priced.
Not when you get it for free;)
We even have a special formula winter power steering fluid:
Cold Climate Power Steering Fluid
Size:Item #:16 oz.1234586632 oz.12345867
Sweet, I love free stuff, where do I pick it up at??:D
