Simple question about axle width, yes I have searched.
NytmareK5
Registered Member
NY
I knew this years ago and forgot, I can't go outside and measure it because I'm out of town for two weeks and would like to order spacers so they are waiting when I return.
I'm looking for the exact difference in track width from front to rear with stock 10-bolts on an 89 K5. I'm looking for a measurement from wheel mounting surface to wheel mounting surface. Front and back. I know it's "around" 3" I am just curious if it is "exactly" 3", or 3.5 or 3.75 or whatever.
Thanks in advance keep the flaming to yourself. I'm just looking for an answer cause I can't check myself, and it's been 10 years since I measured one.
3" is correct. 1.5" spacer per side to fix .
but reason it was done is to help turning circle be shorter .
wider rear = bigger field to turn around in . :thumb:
Sounds good, for some reason 63" stuck in my head but I saw some guys running 2" spacers and was like Qué? Lol
