Started working on console for the new shifter.
Frame is 3/4" square tubing.
free upload pictures
Then covered with 16 gauge steel.
image free hosting
A shot of the underside.
upload pic
Seeing it actually fits.
image post
Once I get some tabs welded to the frame to hold the panels in place, I'll clean up the fit and paint.
The one square shut off switch is going to be used for the winch. Always been paranoid of the winch getting stuck on and have no way of shutting off. Here's the specs.... https://www.bluesea.com/products/9003e/e-Series_On_Off_Battery_Switch
The other is a push/pull to shut the electric down the the motor and everything else..... http://www.longacreracing.com/produ...h-Pull+Battery+Disconnect+Switch+-+2+Terminal
free upload picturesThen covered with 16 gauge steel.
image free hostingA shot of the underside.
upload picSeeing it actually fits.
image postOnce I get some tabs welded to the frame to hold the panels in place, I'll clean up the fit and paint.
