andyblack
Registered Loser
I agree that aggressive tires will cause increased fuel consumption. Think about it. If your tire is providing more traction (which is why you went to the more aggressive tire, right?), then the tires will stick to the ground more, thereby causing you to have to give the engine more throttle to accelerate the truck. It would be like going around with your brakes dragging, only not nearly that drastic.
One obvious thing also: Have you checked for fuel leaks? The gas could be leaking out or evaporating before it has a chance to burn. Remember that cold weather makes eveything contract. Could it be possible that a fuel line or fitting has rotted or come loose?
