Durdyk5
Registered Member
I have a new steering box on my blazer and still have a good bit of slack in the steering. What is the best way to get it out
When you say the slack is coming from the gearbox, do you mean that when the shaft enters the box it's turning a bit before anything happens on the output side of the box? As if the box is somehow absorbing some movement before it starts to turn into movement on the output side? Is it a new box or a rebuilt one? Is it bolted tight to the frame using those stock spacers? And I hate to ask, but is the frame solid...no tears or cracks around the gearbox?How much should you tighten the gear box? The rag joint seems to be fine from what I can tell. Looks like slack is coming from gear box. Also when the truck is sitting still or braking the steering seems to be getting tight. I wouldn't think this is normal. Anyone have any suggestions on what else to look at. Tie rod ends are new and new gear box
Let us know what ends up working for you good luck!Thanks for the help fellas, replacing the drag link this afternoon as well as replacing the old steering stabilizer. Hope this corrects the issue. If not I will break it down some more and look into. Will also probably replace the steering gear again as well
NiceCheck drag link and ball joints. Just did drag link on my crew, huge difference, ends were shot. I had become used to it for a while, drives like it should again. They looked fine static but, as stated above, when someone else wiggled the wheel for me I could see the slop in the joints. I did it truck on, power steering put full force on the joints and exposed the loose stuff. You don't need to move the wheel much, just back and forth a bit. New gear on this one too.
