sm465 and t-case Q
WhislerK5
Registered Member
Tumwater Wa
ok im in mid project with my 87 k5.. i bought it with 3/4 under it with a 6 inch lift 4speed and 208.. i since broke an a$$ load of 44's and put a 60 under it.. I have 2 sm465's sittin on my floor now.. one that came with it with the 208 with a long output shaft and adapter and one with a 205 behind it.. I like the way the long tail shaft shifts and runs.. is there another 205 that will fit beind this 4speed with a long output shaft or am i stuck with the other sloppy 10 spline 465/205 that i have on my floor..
Thanks Dan
round pattern 32 spline 205 is what you need. i believe 83' and newer from th400 or sm465.
i'm sure somebody elso can verify that.
