sm465 clutch linkages
77scottsdale
Registered Member
georgia
is there any aftermarket linkages other than the hydro clutch setups for the sm465 mine is a little wore out and i wont something better
aftermarket mechanical linkages? Not likely if you meen of the performance enhancing or extra stout construction. Your best bet is replacing your parts with new ones from LMC, or better yet getting a hydro setup.
Whats worn out? Everything?
If it's just the clutch pedal, the pedal pivot point is bushed somewhat poorly. You can disassemble that and re-bush it with wrecking yard parts (same bushing as most GM brake pedals similar vintage) or probably get bushings from LMC or somewhere.
