Hey All,
I'm new to the board, I've wanted a squarebody since I was a kid (grandpa had a bright red 85 Scottsdale K20 I always drooled over). I bought my first squarebody back in April, an all original 84 Scottsdale K10, and ever since then its been a constant work in progress. Overall it was in really good shape, just needed some past due TLC on a number of maintenance items. Gave it a full tune up, buffed the paint out, added new dual exhaust, and actually pulled the trans because it was knocking and I thought I had a bad throwout bearing... turned out the trans just needed some real gear oil and the previous owner had been using motor oil. Whoops. Thankfully its an enjoyable truck to work on and I at least got to learn more about the truck in the process.
Since that time ive been driving and enjoying it. I'm just having one problem that I can't figure out I hope this forum can help with. About 2000 miles after i put the trans back in the truck started making a noise at highway speeds. (also lower speeds under heavy throttle). Its load dependent and sounds rotational, but after 2 months of poking around i cant figure out what it is. Its been doing this since august and seems to be slowly getting worse. It typically needs a good 15 miles on the highway before you really start to hear it, otherwise its quiet. Ive eliminated the inspection cover, u-joints are good, I can't find anything thats vibrating. Clutch and gearshifter both work perfect. A loose throwout bearing / fork is suspect but the noise doesnt really change if i put pressure on the clutch pedal while cruising. If I stay on the highway at 65+ for an extended period of time the noise gets rather loud, to the point you cannot ignore it. I want to take the truck on some road trips next year and the way it is acting i can't trust it to do that. I'm suspecting an input bearing but I want to be sure before I pull the trans all the way out again... I just finished this project so I'm well practiced but that was a lot of work!
Anyway, here's a picture of my truck and a video of the noise. Thanks for any help!
-Joel
-Joel
