Matman2010
I have an 84 chevy crew cab that I converted to 4x4 and also converted to a manual transmission. I have all the hydro pedal assembly and got the master and slave cylinder out of an 85 chevy truck. I am having trouble not getting enough travel out of the slave cylinder to disengage the clutch. The motor is an 84 J-Code 6.2 and I am running a 76 SM465 with a Np205 and I made my own bracket to mount the slave cylinder. (Cant post a picture of it, but it is lined up right with the fork)
Everything for the clutch is for a mechanical linkage, It seems from what I have found there isn't really a difference in the forks between a hydro and mechanical. I am currently getting about 1 inch of travel out of my slave cylinder, I have found that I need at least 1.5 inches to get it to disengage. I am using all the factory master and slave cylinders and from what I have heard the mechanical clutches will disengage with 1 to 1 1/8 inch of travel on the fork. So where could my trouble be at? I am pretty sure that I got all of the air out of the system, but it seems that I am getting a 1 to 1 ratio between the slave and master. I have pulled the clutch back out and it seems like everything is working just like it is suppose to but I am not sure why I need 1.5 inches of travel vs the 1 inch people keep saying it should be.
Thanks, Matt
Thanks, Matt
