Just in case it makes a difference in bearings, seals and rebuild parts it appears ( by your pictures ) that your ‘87 model K5 has an older style ( ‘81~’84 K5~K20 ) style long-foot mount adapter and related crossmember - this could mean that your 465 and/or 208 might not be from an ‘87 year model.Hello all, i appreciate all the support i have recived in the past here. My 87 Blazer has the SM465 and NP208 both of which need new bearings and seals. I was considering doing this myself.
the 208 leaks like a siv and pops out of 4 wheel if i dont hold the stick back somtime, i think mostly in 4L. the 465 shifts ok, somtimes need to drag the clutch to find reverse and of course it leaks as well. need new drive shafts front and rear as well but that i an easy one to solve for me.
first problem i see is tons of cheap chineese bearing and seal kits on Ebay for both transmssion and transfer case. are there good bearing kits out there. it seems the 208 is pretty easy to rebuild acording to youtube, what say you.
second problem is i have heard the 465 if not done properly will pop out of gear. i have never rebuilt a vehical transmission but i am a capable industrial mechanic.
Does anyone have a manuals or guides on rebuilding both units or a weblink they trust.
is there a recomended shop in the west you would recomend. I am In wyoming. just trying to weigh my options here. should i find used 465 and 208 ship them to a shop or ship mine out to a shop or bite the bullet and try it myself? I really dont want to have to park this beast for several months. love driving this thing when home instead of my 2017 Ram.
Any help is appreciated thanks again.
I can’t think of any internal rebuild type differences between those years but it might be good to know when ordering parts.
While you are ordering parts for the 465 get the third gear snap-ring replacement sleeve upgrade - it’s cheap and well worth it.
Also, just as mentioned above the shifter tack welding tip will make a huge difference in shifting feel and driver comfort - do not skip that tech tip for it is great advice !
, not to discourage you but don't be surprised if both are just as leaky after the rebuilds.
