Vortec heads, steam holes for 400 Eng? Head gaskets with steam holes?
Cracked head or bad head gasket would have milky colored oil and or white
Smoke from exhaust generally. Is your rad being pressurized and bubbling in overflow bottle?
Blow by pressurizing crankcase is compression getting past the rings or a cracked cylinder. 400's are Siamese cylinders and don't like overheating
(Steam holes) a must have.
I have not had noticeable blow by with any engines I have put together.
Misadjusted valves and blow by doesn't sound right to me.
U have an internal upper end problem in my Opinion. Pull a head on
The #7 side or give it back to the shop.
Is this a driver? 11:1 comp, why? With that cam what is your actual running compression . Plus 1.94 valve steel heads.
Something has failed. IMHO.
WT$. I noticed the bearings were scarred and washed off with all the gas that had gone inside the crankcase. Further inspection of cylinders 1,3,4 and 5 showed me the problem. Those pistons were broken between the top and 2nd rings which explains all the blowby I was getting.
