Fatrat
Registered Member
Alright here it goes, I've read a few posts similar to this but not what i'm looking for. I have a 400 (carbed) in my 1990 blazer. It was running great then one day as i'm driving i a loud hizzing sound in the engine bay and tons of smoke coming out. I'm thinking a water hose broke, but my temp was at 175. I pulled into a parking lot and noticed that the valve cover breather on the passenger side was pushed out and some oil came out, not alot but enought to notice. At that time i only had breather on the valve covers, and smoke was coming out from them like steam engines, constant thick white smoke.
Anyways, i have since installed a PCV system and it helped, but the smoke is still there, just circulating around or coming out the air cleaner but not as much. If i take out the breather on the passenger valve cover tons of smoke comes out. I apologize for the lengthy post but the just trying to figure this out. The engine was freshly built 8 months ago. It has keith black pistons with foating pins, moly rings, and 6" eagle rods, the heads are vortec and were rebuilt with the engine. I spoke to the machine shop and they said to run it hard to allow the rings to seal and if it doesnt stop they will cover the rebuilt again. Tomorrow i will do a compression test to start, any other thoughts or comments are welcome, before i decide to pull it out. The engine only has about 250 miles on it since the build and its strong as hell, just the smoke issue.
..I've seen flooded engine burn the gas off with a lot of white smoke too lately,I think the alcohol in the new gas absorbs a lot of water...
. Are these hydraulic or solid lifters you are using and how are you setting the valves? When you said that #7 had no compression and then you adjusted, was #7 way loose or way tight initially?
