Hossbaby50 said:What about using one of these?
That is what I use for rear recovery on my truck.
Harley
The only thing you have to watch out for with those is the weight rating of the shackle. If you look at what is stamped in yours you'll likely be scared. Just remember that they are rated for overhead lifting to OSHA stds. The Factor of Safety is at least 3 times, and might be as much as 5 times the max rated load. To be safe I would limit the 'overload' to twice the weight rating. So if it's rated for 4,000 lbs consider the max to be 8,000 lbs and remember that when the slack goes out of the strap the loading could easily be twice the vehicle weight. Billavista's article on winches has some rules of thumb for estimating how much a given stuck is going to load all of the recovery bits.
Out of curiosity I calc'd the area in shear of the 1" ball shank and the 5/8" hitch pin. The shank is in single shear while the pin is in double shear. The pin is still smaller than the shank so it should fail first. For the ball's shank to fail first indicates that some bending load is adding to the Stress on the shank of the ball.
