So I have these axles....
Blue84K10
Seattle
My friend just gave me a set of axles (12bolt chevy), leaf springs and blocks for a rancho four inch lift, and a 203 transfer case. I have a 84 short box with a manual four speed, that has a 1978 400cubic in V8. I also have 10 bolt axles right now. I was thinking about putting a rear disk brake kit on the axles before the install. Since I am new to this "SUPER NEWBIE" I was looking for suggestions on what I should to do the axles now before they are installed. Any tips concering preventive maintanaince and such. If you have any other suggestions or helpful advice please let me know. Thanks in advance :D
Put in a 14-bolt, and join http://www.krazyk5.com.:D
The 12 bolt is stronger than the 10 bolt, but not enough to make a big difference. I wouldn't say it's worth the work of the disk brake conversion either. A 14 bolt can be had for VERY cheap around here, I basically just had a guy pay me to take one if you do the math a certain way.
Okie dokie I get it, so now it it time to go look for a 14bolt for praticaly free... Umm anyone know a good place to start looking around Seattle? Again I am a newbie with no shop connections. The 12bolts do have warn locking hubs so I am thinking of taking those and keeping them. Thanks for the help I guess I will start looking =)
yes you guys were right there is 12bolt rear with a 10 bolt front with the warn hubs. I have pics but now I have to figure out how to post
Why are you wanting to change your current ones out? Are the gears better in the free set you just picked up?
Strength wise there is no reason to change them out. The Warns can go into your current axle.
You don't have to change the axles to install the lift kit. You would need a few other things to make the lift complete....
Still looking for the next to free 14 bolt. My uncle said he is going help me change the hubs cause he has done it before and the only wrenching I have done is ooil changes and brakes. TWO MORE DAYS and I get my own tools! If any of you have know any posts that a newbie should check let me know. I know that all the questions that I have asked and am going to ask have been asked before so any help would be appreciated!
Well my wallet and you are on the same page. My budget is putting my project on hold right now... Let me know peoples if you have seen any of these great deals floating around =)
Well here is the deal. I am going to swap in the 12bolt untill I can find a good deal on a 14 boltff. Plus I guess I can use all the practice that I can get doing the swap. LOL The truck yard offered me one for $550 with what ever gears that I need installed, Is that a good deal? On my way to the truck yard my transfer case or transmission started slipping. When it pops out of gear all I have to do is stop but it into 4wheel low and then back to 2 wheel and it works just fine. It pops out on the highway but not in stop and go traffic. Would some please tell me that it is my transfer case and not my tranny, I have an extra 203 sitting on my porch so that would make things much easyer for me. Thanks for all the help people and the patience w/ dealling with my dumb questions!
I see 14 bolts go for around $100 all the time.What gears do your front ends have?203s have a weird linkage that can cause that problem:dunno:
Good luck
