So I know what I want to end with...
babyburb
1H North of Dallas
but not sure of how to get there with the correct parts. Especially with the entire drivetrain swap. Bare with me because I do not know what will fit with what but here is what I want to end up with.
As of now I run a stock 400/350/203 combo with D44 and 14ff. I have a 454/400 out of a C20 crew cab PU. I want to swap out the 203 with a 205. This is where my questions begin. What 205 am I looking for to match up with the 454/400. I have no clue of what year models, splines, and whatever else I don't know about to be looking for.
I also want to swap out the D44 with a D60. Will the conversion to the 454/400/205 and D60 change the lengths of my driveshafts?
Until I get the D60 will the driveshaft length for the D44 pumpkin work?
Any advise would be helpful. I will be hitting the local junk yard next week on my vacation week.
Thanks
I forgot to mention that the t400 bell housing would be swapped with a pre 71 to install a heavy duty sprag. I think that is what my transmission guy said..... I dunno???
4wd TH400s attach to np205s with 32 spline shafts (female on the 205 end). There are 3 different 32 spline outputs for the th400 though. The super short one is for the th400/np203 combo... as far as I know either of the other two could have come with np205s stock... depending on the year/adapter. :dunno: If you are going to rebuild your th400 anyway, you can always swap in whatever output shaft you need.
attachment.php
yes, IIRC the shaft will be slightly shorter post-swap. The t-case flange end might be different also, I dunno... never run a 203.
Hard to say, depends on a lot of factors... lift, what shaft you have now etc etc.
upgrading the sprag for the older style 35-element sprag is a common upgrade. This shouldn't require an entire bellhousing change though. The only bellhousing upgrade that I know of would be an Ultra Bell from JW Perf.
j
