On your 500 cubic inch cadillac motor with a demon carb on a factory intake. Reuse the Rear AC bracket from the cadillac motor. Use .625" spacers on it to push it forward and line up with the cadillac pulley. Fabricate a new front bracket which is a pretty simple piece. Use a 1/8" NPT BRASS 90 degree fitting to turn the breather at the back to the side, ITS not an NPT thread but you can make it fit! BRASS!
Grab yourself a set of AC lines off of a s10 blazer Late 80's maybe and bolt them on and your done.
What does this mean to you, probably not a damn thing but it was interesting and the first thing I've done on my crew cab for at least a month so I thought I'd share!
