So, if ya get to puttin AC
cybrfire
1 ton status
Iowa
On your 500 cubic inch cadillac motor with a demon carb on a factory intake. Reuse the Rear AC bracket from the cadillac motor. Use .625" spacers on it to push it forward and line up with the cadillac pulley. Fabricate a new front bracket which is a pretty simple piece. Use a 1/8" NPT BRASS 90 degree fitting to turn the breather at the back to the side, ITS not an NPT thread but you can make it fit! BRASS!
Grab yourself a set of AC lines off of a s10 blazer Late 80's maybe and bolt them on and your done.
What does this mean to you, probably not a damn thing but it was interesting and the first thing I've done on my crew cab for at least a month so I thought I'd share!
you ever get the power into the stereo?
U ever get ur vice grips out of ur fender?
Were are the pics. You know I am interested being a cad 500 junky myself.
I'll post up some pics when the motor goes in. Shouldn't be too long now. Some brakelines in the frame rails and finish the accessory brackets for the motor and then I can slide it in.
