So on our trip, really bad milage dmax
I replaced the fuel filter and the air filter. I have only driven a short period with it. Less than a mile. It feels way more powerful. Moves out way better.
250 miles tomorrow and another 200 the next day so should have a good read on milage numbers
How has the truck been these last few days?
What happened on the way home? Was it better?
Nope, I checked every time for milage, started using my god for dead accurate miles. Got mid nines mostly on the way home.
Then after we got home and unloaded everything cleaned out the fifth wheel and sent my mother in law on her way to her house, well real problems then.
I will very soon be tearing into a lb7 to replace head gaskets. Gonna do injectors too.
So got home Saturday morning. Got her call and took off to borrow a truck and get her truck to my house and her fifth wheel to her house.
So did you confirm it was eating coolant? I know you said the coolant overflow was black.
I haven't investigated any further.
I'm taking today off of life.
My head hurts
Pic of the coolant reservoir
Make sure you do something about the injector cups while your at it. Gotta love it when shit hits the fan!
I'm not sure about the LB7 engines but on the LLY when you pop a head gasket they tend to push coolant out of the overflow. Instead of sucking it into the engine the combustion pushes exhaust gasses into the cooling system. Mine did just that when I lifted lifted the heads.
That picture could be just massive amounts of raw diesel not being burned, due to bad injectors. Look at resealing replacing the cups when you do the injectors, reset the valves while your there too.
Why would the coolant be black?
I'm gonna have to do some investigating soon.
Surge tanks turn black when you are getting combustion gasses in the cooling system. 6.0L powerstrokes do it all the time. I have one at work currently that has an almost brand new surge tank that's totally black inside. It most likely has cracked cyl heads. I would venture to guess that your Dmax either has bad injector cups letting combustion in the cooling system or a cracked head(not sure how common that is on Dmax) or possibly just a bad egr cooler(Don't know much about those either on a Dmax). Napa sells a combustion gas test kit that uses a blue fluid that turns green with combustion gasses to test the cooling system. I've had really good luck with it.
