A ground terminal with 2 wires and a 1 pin connector from the spark box. Neither of them are plugged into anything. The grounds have me a bit concerned but I cannot find any place where they would go to. They come out of the harness that comes from the knock sensor behind the distributor. I was going to cut them and solder some wire and run them to the nearest grounding spot.
The 1 pin connector that isn't plug in by the distributor is am not as worried about, but I don't have a clue what it is.
Thanks,
Jeremy
Thanks,
Jeremy
