CA Soft top
bmxbryant9
Rebuild reboot
Petaluma
Does anyone know where I could find a soft top for a blazer? Not really concerned with year just figured I would ask around here. Anyone want to part with their own?
i found one on craigslist, had to modify for missing parts but works great, also i found a lot more out of phoenix, AZ, that's where i bought mine
Sweet. I know I'll have to modify one for mine be cause I have a funky setup with my top. I might just get a custom one made that stretches over the cage
I have an STC FastTrac for a 76+ K5 I'll be selling as I just cut the roof off of my K5.
The good: (faded) black w/ clear windows & complete (frame, hardware, etc).
The bad: it's "high mileage", meaning it's got mud stains and the windows are pretty scratched up. The top is a little "baggy", you could probably move the frame pivot bracket at the center of the bedside back some to tighten it up (if you don't mind drilling). I also had a problem with the track system holding in an area about 12" long right at 12 o'clock on the roof. I might have been able to fix it by squeezing the track to better hold the lip on the top but I didn't want to do that knowing I intended to sell it after cutting my roof off.
This style of top has a track / lip system around the perimeter similar to a Jeep top. The track bolts to the body in the factory holes on top of the bedsides but you will need to drill 20-25 holes in the cab for the rails that run the arc of the roof and probably 10-12 for the rail on the tailgate.
$300.00 shipped
These are the best pics I've got.
I might have to take you up on that. I don't really care about the wear on it too much because my blazer is pretty rough, more function over form. Are you in a hurry to get rid of the top? are the windows the full length of the open area? your blazer is sick! have always dug it!
Thanks! :thumb:
The windows do cover the entire open areas.
I'm not in a hurry right now, I need to get thru Christmas before I'll have time to mess with the Blazer again. I'll need to move it mid to late January so I can buy some more tubing for a cage.
that is the same top i found on craigs list... but see how mine sags on the sides, i like how yours is tight all around, im missing the frame rails that go around cab and tail gate20151207_123129.jpg
