SOLD!!!!Dana 60 SRW Front Axle 4.10
GonicGM
Seacoast New Hampshire
Dana 60 SRW 4.10 kingpin front end from Chevrolet K30 one ton 4x4
Housing: fairly clean, undamaged, unmodified, shock mounts good.
Knuckles: spindle surfaces flat filed, face and ID coated to prevent rust and seizure.
Axles have good u-joints.
Spindles: Pin needle de-scaled, wire brushed, flat filed and cleaned, needle bearing lubricated, mating surfaces coated to prevent rust and seizure.
Caliper brackets: Pin needle de-scaled, wire brushed, faces flat filed, faces and ID coated to prevent rust and seizure.
Locking Hubs: Warn, manual.
Passenger side pumpkin
$795 as it sits
Have DRW hub/rotor assemblies to convert to DRW if needed. $495 as DRW
Can arrange free delivery off rts. 95 128 93 495 395 from Wells Me. to New London Ct. (NH, Maine, Mass. Ct. RI)
Is this a bolt in and go setup? And do you have a matching 14 bolt for the rear?
