rwright07
i just swapped my 4.10 pass drop 3/4 ton dana 44 out for a 60 so i no longer need this.
The axle is in great shape, i has got highsteer and crossover all set up. comes with the draglink, heavy duty tie rod, 1 ton TRE's, 3/8 plate Diff cover w/ drain plug gaurd, brakes, rotors.... EVERYTHING
roll it under and bolt it on. Ive even got the spring plates and ubolts if you wanna re-use then (not everybody would advise that but they are yours if you want 'em)
this axle has had the balljoints replaced less than 6k miles ago. Has always worked flawlessly.
1350 joint at pinion
looking for $600 obo
I am located in San Luis Obispo CA
I can be reached at [email protected]
or
by phone at 253 961 1942
--Rick
or
--Rick
