5280k5
Got a set of USED Pro Comp/Earls extended brake lines. They should fit Dana 44 front axles w/ 7/16" caliper banjo bolts and 14 bolt rear axle with the stock brake line T fitting. The front lines are 28" long and should be the ones for a 4-6" lift, never measure rear but came of same truck so should fit same size lift.
One front line has a small section of braided steel that looks like it got nicked on something but line is ok.
$40/shipped.
$40/shipped.
