**SOLD** WFO Dana 60 high steer arms - springless
mrk5
The Sticker Guy
Moderator
Vendor
Author
Northern Colorado
I have 2 indentical arms. They are used for high steer with the tie rod behind the axle. Both arms have the tie rod side drilled for 3/4" bolts for heim joints. The passenger side arm has the taper for ES2027 draglink ends for connecting the draglink from the steering box. The driver side arm hasn't had anything attached to the front hole, but there is a hole for a 5/8" bolt for use with a heim joint. I can include a used draglink end if needed (http://www.wfoconcepts.com/pr/7-8-18-RH-thread-Draglink-end/3163/3204/3241/3836) As well as a pair of used heim joints.
Both of the arms are like the item on the left in the picture on the webpage http://www.wfoconcepts.com/pr/Dana-60-HDA-Double-Arm-Set/3163/3168/3462/3445
Swapping my axle into a new project and these won't work.
I will include studs & nuts. Similar kit new is $335+shipping. Asking SOLD $190 including shipping (flat rate USPS) to lower 48. Used drag link end referenced above would be an additional $20. Pair of used heim joints for an additional $20.
Driver side:
Passenger side:
