Sold
kennyw
@squarebody.chop.shop on IG
Stevens Pass Highway, WA
Older cast iron case Ranger Overdrive unit. 2 speed gear box that mounts between bellhousing and SM465 or SM420. 27% overdrive $325 SOLD
Ranger overdrive - do you have the shifter and how much shipped to 32504. There is also a forward air depot here in Pensacola, FL
I do have a shifter for the Ranger OD... I'm not sure how it was mounted though as the guy I bought it from didn't take any pics before disassembly. I wanted to rig up an air cylinder to shift it via a switch on the transmission shifter myself.
I'll ship it via Fed Ex Ground for $50 too.
F.Y.I. The original Ranger overdrives used a two speed rear end switching motor-think two ton truck. I'm not sure how difficult it would be to adapt one to a later model. This was before they were bought out by Advance Adapters. Hope this helps.
Jimbo
If you look at the pic above and compare it to the current models (check advance adapters web catalog) you can see the version I have is setup for a linkage to the shifter rather than the shifter mounted directly on the rod that sticks out the side. Should be easier to use an actuator on my version than the new ones.
Ok Jimbo... I'm sure we can talk you into it... just want to see what Rob says first.
Let Jimbo have it, I want it but just can't commit to it right now.
Thanks anyway.
Anything can be shipped... only question is the cost. These were built kind of heavy. I'll check with a friend that has a business discount for truck shipping and get back to you.
