wasted wages
1 ton status
T-400 / 203 /205 ORD doubler....
Ever since I installed my doubler, I have noticed two things happening...
#1 when I put the trans in gear ( reverse - cold ) it seems like it takes a while to engage... I have to rev it up a bit like it's low on fluid ( level is fine ) to get it to start to move.... once it moves and warms up.... no problem... the trans has a deep pan and extended pick up also...
#2 when I stop and shift from drive into neutral then thru reverse into park,,, I get a ratcheting sound, like the parking pawl in the transmission is engaging as if the buggy was still moving.... it happens when I shift from reverse to park.....
I have an art carr shifter so I have to hit all the gates on the way to park.... the ratcheting noise points to something still spinning inside the transmission even though the buggy is sitting still....
It didn't do this until I installed the doubler.....
I have an art carr shifter so I have to hit all the gates on the way to park.... the ratcheting noise points to something still spinning inside the transmission even though the buggy is sitting still....It didn't do this until I installed the doubler.....
