Today's adventures will be to get the new tires pit on, replace rubber hoses ie axle vent lines, vacuum lines, fresh grease were appropriate.
add power steering fluid an bleed it, hopefully I won't have to replace the steering box Since that's the only leak we have seen.
then to figure out why the high beam lights don't wrk.
The top lights (regular ones work) but not the bottom ones do not come on. although we can see a difference when the switch is activated.
any help or pointers there would be appreciated.
I have been contemplating adding a foot dimmer switch to the high beams, but would rather fix the current system.
