DEMON44
Low-Tech Redneck
Not that I'm aware of. I believe with the introduction of the 245hp HO in '01 came the bigger input..........BUT ya never know. Just like you may find a 53 blocked ISB way later than cummins said they stopped useing them.
New adapter components are available to adapt the NV5600 4wd transmission to the NP205 gear driven transfer case. This kit includes an adapter plate and shaft coupler output shaft NV5600 to input shaft of NP205, your cost $401.21, order kit part number MTCNV5600-205
DEMON44 said:Early '98 are 12valve and '98.5 is 24valve. '98 12v are the golden goats. They got the true quadcab with 3rd&4th door. and nicer interior. but also the creme De La Creme of the P7100 injection pumps. the 913s in the '98 stick trucks and are the top dawg.
That '97 is a solid 12 valver though......... with NV4500 and a NP241DHD. Theres still an engine wireing harness and ECM that may be damaged. You;re still going to want the grid heater relay harness and the fuel shutoff solenoid wireing out of it.
CDA 455 said:Is there a 'better' era of Cummins, one engine over another?
12v vs. 24v?
original balzer said:now say the injector pumps burnt up would that be costly to replace? as well as any other components on that side? The PS pump isnt a prob, the vacc pump may be spendy if its anything like a 6.2 lol.
Balzer
DEMON44 said:Geeze, thats getting almost to personally preference territorry.
IMHO.....and NOT ranking the '07 6.7L Cummins due to lack of time in service
#1- 3rd gens ('03-'06) commonrail injection with bosch highpressure CP3 pump
#2- Early 2nd gens ('94-early '98) 12valve Bosch P7100 injection pump
#3- Late 2nd gens ('98.5-'02) 24valve Bosch electronic VP44 injection pump
#4- 1st gens ('89-'93) 12valve Bosch VE injection pump.
Each has its own set of "issues" I'd say.
