source for OEM muffler heat shield?
badmix
West Virginia
Sorry if wrong section, looking for source for OEM heat shield for muffler factory location. Or if anyone has one laying around (junk body) it would probably still be attached
Are the all the same? Which one do you want and I’ll see if I can get one apart.
I need the one that goes flat and the one that is jus behind it that kinda S shapes up to the floor (if that makes sense) this one is 4 bolts.
84 K5
Here are the two pieces I have. They've been off the truck for so long I don't have a clue what they are for. :thinking:
I'm not using them and they are just laying around collecting dust.
The larger piece has a hole drilled in it from previous owner. I'm not sure what it was used for.
If those aren't what you need, I might have one: it's about 12" x 6"? I'll see if I can find it this afternoon and send you a pic.
