I was poking around the burban today and noticed how there's alot more room between the firewall and distributor compared to my blazer. And I remember when I put the doubler in. It would hit the underside of the body if I tried to put it where I wanted it. I'm pretty sure this is from my frame being bent up. So my the top of my distributor was very close to the body. From the drive train being angled down to clear body/doubler. Now that I'm putting a 5.3/6.0 in....Im worried the motor will hit the fire wall...how much room is there between the very back of motor and firewall? Pics would be great. If you got a th400 would really be helpful
I know driver side front frame rail is 1 inch higher then the passenger side.
found that when I was mounting my shocks and bump stops.
it will fit. But I need to figure out some adjustable motor mounts so I can slide motor back about 1". With the current motor mounts its 1" to far forward.
I'm going to try and wallow out all the tcases cross member holes and try to move it forward some. There's no way I can access the back of motor.
