spark wire location UPDATE POST 14
At this point you need to pull the cover and verify for yourself that the marks are either lined up or not. Just remember like i said earlier, when the engine is on TDC of the compression stroke the marks should not be pointing at each other. If you were to bring the number 6 cylinder up to TDC then pull the cover they should be lined up correctly.
ah ok on thursday i will tear it apart and check. i will post up what i find.
Blue85, thanks for the clarification that helped a lot
