1990 k5 Blazer, 241 transfer case, stock speedo in dash, odometer working
Background: I was driving on the freeway when the speedo just went to zero. Didnt work for at least six months. On a couple cold nights recently the speedo sprang to life. It worked fine all the way up to 45mph, but then died. Speedo has not been working for at least a week now.
When I turn the key on, I can see the speedo raise up off the perch at zero, but when I drive it doesn't move. When I turn the key off I can see it go back down.
What could it be? VSS in transfer case, DRAC module, Motor in speedo, bad wiring?
Do those symptoms sound familiar to anyone. I searched a bit, but didnt find anything
