Black Beast
Newbie
Ok so I’ve had my K-5 for about 6 years now, I love the truck, but I’ve got a problem and for once I’m absolutely stuck on how to fix it.
I’ve got a 1991 Blazer 350/700R4/NP241 combo with 10 bolt axles (3.73 gears) and 32 inch tires. Last year I blew out the rear end (silly me entering it in a truck pull), and swapped the 3.08 10 bolters for a set with 3.73 gears. Just before I swapped the axles, my speedometer went nuts, it started bouncing between 0 mph and whatever speed I was actually going. It did this for about 10 miles and went away. I swapped out the axles and drove the truck for a while, no problems. Several weeks later, the problem came back for a few days and then went away. I knew that my speedometer was off, cause of the new gears, so I performed the DRAC module modification, where you remove the jumpers and install a 8 DIP switch block in place to recalibrate the DRAC module (found on tbichips.com/drac). This fixed the speedometer calibration, but the problem came back a few days later except this time the speedometer went dead, the needle lifts off the resting pin when you turn the power on, but never moves from there. It went away a few days later, I figured it was a bad Vehicle Speed Sensor, so I coughed up the $70 and replaced it. I drove the truck for a while, but a few days later the problem came back. So now I’m out 70 bucks and I still don’t have a working speedometer…….HELP!!!
I don’t think that my modification made it any worse, I’m guessing it’s a bad wire or something……anyone have a wiring schematic?? Or could it be the DRAC module, or worse the ECU?? I don’t want to keep shotgunning this. Thoughts??
