Anbody have part numbers for the 10 bolt crowd hardware? My hub is loose and the "tit" is broken.
Both nuts and washer in correct positions. Just got my new Dana spicer spindle in the mail. I really would like to follow the torque specs in the factory manual for the lock nut but now I’m scared Funny that everyone I talked to says when they removed their hubs for the first time, or switched hubs to manuals that both of those spindle nuts were pretty loose, including mine. I’ve had this truck for 20 years and never had a problem with bearings, even with relatively loose spindle nuts. I never removed a hub on this truck in 20 years either. The truck is in like NOS condition and is always stored in the garage. I’m also installing warn premium hubs while I’m in there. My truck sees minimal 4 wheeling so also considering if I should just put the auto hubs back in and skip the warnsSure you didn’t put the inner nut on the outside and catch the pin on the lock collar?
I bottom mine out with the impact. 3 ugga duhgas per request of @ryoken
If your “tit” is broken chances are you’ve experienced the same problem I did with the washer walking out of the grooved key way and onto the threads. That’s really the only way to break that tit.Anbody have part numbers for the 10 bolt crowd hardware? My hub is loose and the "tit" is broken.
I just watched a video from SEMA both from stage 8. They make mention of the stock washer walking onto the spindle threads just as mine did so I guess it’s a known issue.Im wondering if Skunked was right. Something is out of spec or worn out. Really not a common issue
I subscribe to this manualI tighten that outer nut to insane torque. I tighten is as tight as I can with my 1/2" breaker bar. Never had an issue
This is what happens when the pin is not sitting in one of the holes. A little grease helps keep things seated while you run the outer nut, but it's always worth a visual inspection before driving it tight. I've also heard of it happening when a wheel bearing locks up, but never seen it.I tightened to 185ft lbs and the lock washer (with the holes in it) spun and dig into the threads passing up the groove or channel in the spindle. In doing so it also broke the “tit” off the preload washer
