Sawzall is useless on those bolts...use a grinder with a cut off disc. Get the disc up between the spring and the INSIDE of the hanger...just cutting off the head of the bolt won't help you.
Rene
I actually used a sawzall but I had good brand fine tooth high count blades, and then I recently found those blades that are carbide dipped and they work like a charm.
And by the way, the bolt isn't that hard, it's the sleeve.
I had the same problem at first.
/forums/images/graemlins/yikes.gif /forums/images/graemlins/hack.gif will work for you.
/forums/images/graemlins/grind.gif will also work but I like the /forums/images/graemlins/hack.gif better in those tight spots.
/forums/images/graemlins/woot.gif
Rene
