For me to get my K5 registered in Pennsylvania the front and rear bumpers can only be a maximum height. When I bought the K5 the front bumper was 33" and the rear bumper was 35"
PA LAW - GVWR 5,001 to 7,000
Front MAX = 27"
Rear MAX = 29"
So, I needed to lower the entire vehicle a net of at least 6 Inches!!!!
My tires were originally 39.5" and I just installed 35" tires.
I just measured the Blazer. AFTER the tire change the front bumper is now 31" and the rear bumper is now 33" So only TWO inches lower, which makes sense because the tire diameter was about 4 inches less so half is 2"
I still need 4" less bumper height. I need to keep the 35's
The seller said the Blazer had a 4" Spring lift and 2" Body lift. The body lift should not have any affect on the bumper height.
My front spring seems to be 47" eye to eye and rear springs seem to be 56" eye to eye (this may be off a bit - possibly 59" - it was dark when I just measured).
I sent photos of front springs and rear springs. Maybe someone will see someplace I can change things. I see springs on ORD but the smallest is 2"
Maybe the springs on the K5 NOW are actually part of a taller lift (more than the claimed 4"). Any help or ideas are welcome.
I need to get this K5 lowered. I need to lower it 4" minimum.
Something doesn't seem right.
Front MAX = 27"
Rear MAX = 29"
