spring or blocks
dmoney said:
will I get a better ride out of springs or blocks?
Depends what kind of ride you talking about.
The block will keep your stock springs so ride will be the same, softer than any lift spring, but there is a risk of wheel hop or spring wrap if you plan on puting 38's
:D
dmoney said:
what if i go with a ladder bar set up to help with the wrap?
That works a lot of people do that to fight axle wrap and it doesn't affect the ride quality.
:D
I have the helper spring and 4inch blocks now but the burban has that ass sag, so I need to redo it with something alittle higher
The ride will probably be a little rougher. I have a ORD 4" shackle flip and a zero rate. The zero rate gives me that extra 1" to combat arse sag and works great.
Being a pic whore - here it is with 37's, a 4" flip and zero rates -
