spring perches
cybrfire
1 ton status
Iowa
1 piece folded construction. Unfortuantely at this time, this only applies to stock height perch 14BFF.
thanks bud! Did clean them up a bit didn't it.
They got here yesterday. Pretty nice stuff. My only complaint is that I forgot to order new spring plates. :doah:You have another order for those. :D
Code:
bummer man! Better get something else in the same box for shipping savings!!!
I don't see any ubolts on your site, but if you have them and read this before the plates ship, I'll take 4. I can paypal the difference.
I'll have Tracy send a paypal request. Thanks again brother!
Thanks! In case it isn't obvious I need the bigger ubolts (Is it 3"?) for the 14 bolt to match the plates. I don't have any blocks back there so the stock length is probably fine.
3 3/8". Got ya covered. They were recently removed from back order status.
Brian, why stop there? If you don't already have Kerts guardsman pinion guard you should add that to your list also.
I thought about it, but between the brake calipers and the gears, I have more money in the axle than I should. I actually want to drive it soon.
You can either pony up the money now or later, might save you some shipping cost if you pony up now though. You know you're going to want this sooner or later. :D
Ha! I'll pay later. I'm figuring I'll add the pinion guard at the same time as adding the locker. There's no reason to guard the pinion if I can't get the truck onto anything that'll scratch it anyway.:haha:
Would these help if we did up a kit with all the pieces?
Perches, plates and ubolts or maybe just plates and ubolt?
