big_truxx
whats the difference between 1/2 3/4 and 1 on springs both front and rear? are 1/2 & 3/4 52" rear and ton 56"? and is the front 48" on both the 1/2 and 3/4 and the ton bigger or are they all the same on the front?
actually i think most 3/4 ton trucks got 52" rears. i have had 5 of the 73-87 year range and all had 52's. i had 2 3/4 ton suburbans and both had 56's.boz42 said:all frts are 48", rear 1/2 got 52" or 56". all 3/4 & 1 ton rears are 56" this is true on the 73-91 solid axle trucks
i think 1 tons had 3" wide springs, front anyways. 1/2 3/4's had 2-1/2big_truxx said:i had heard that all the crew cabs did have the one ton frame. but its cool that all fronts are the same. whats the difference in the 1/2, 3/4 and ton front springs? each have a leaf more than the other?
sh%t sorry!84_Chevy_K10 said:All of our trucks have 3" wide front springs. Aftermarket lift springs are 2 1/2".
1/2 tons 52s or some had 56s
3/4 tons, most 56s, some 52s
1 tons, 56s
Front springs can be two, three, or four leaf from the factory. My K10 originally had 3 leaf front springs because it had that listed as an option.
