spring ?
73hillbillyk10
rhode island
looking at a set of 4inch lift springs but the fronts are 3 leaf hd ones how stiff are they truck they are going into would be dd trail truck it has 1 ton leafs on it now way to stiff any ideas
I'd be inclined to pull the center leaf out and replace it with one of similar length from the stock pack. It's worked well for me before to swap leaves around like that. It's either that or look for a softer set of springs instead.
ill probly pull a leaf because the ones on the truck now are like a ton and a half the truck was used to hall wood befor i got it
