Springs, t-cases, trans, and more
b454rat
Binghamton NY
Brand new never installed BDS 8" front springs, 73-87 GM, no bushings. $250.
Procomp 6" rears for 88-up, has an extra long leaf added, w/longer shackles. $200.
TH400/Ford 205, 2wd trans, 2" thick spacer, 208/241 adaptor. Ford case has the rails ground for twin stick, just need shifters. Has stock style flange output, rear has 1350 yoke. Have a shift kit for the trans, too. SOLD
TH400/203, don't know anything about it, got for a doubler, but don't think that is gonna happen (:( ) Still bolted together, really don't want to seperate. $250.
GM 205, 400 8 track style w/adaptor, but no input. (It's in the above 400/Ford combo) All stock, came out of an 81 crew cab. Adaptor is really nice, no cracks, striped threads, nothing. $250.
Brand new 1410 rear yoke for 203/205, never installed, opened the box to see how huge it is. $75.
Brand new 1410 yoke for a 14ff. $75. These are new Spicer peices.
TBI 454, complete motor, ECM, harness, anything that attaches to the motor. This motor runs 110% perfect. Does not smoke, knock, skip, or make any funny noises. It's not the original motor for the truck, has some bluw paint on the balancer and behind the flexplate. I can't see the numbers to see exactly what it's out of, or if it's 2 or 4 bolt main. It has the Quadrajet intake, so a 4 barrel will bolt right on. Only oil leak is out of the dipstick tube where it goes into the pan, it's more like a seep than a leak. Also have a flywheel, recently turned, but will need a cleanup, been sitting for a while. Also new clutch, intalled on a flywheel, but never had a tranny on it. $1500.
I'm parting the truck, so if you need something that isn't listed lemme know. The ORU kit is sold already.
Everything is best offer, I can ship from business address. Any questions, drop me a line, 607-237-0067. Thanks Joe.
Pics are in my sig.
They are strap style. I thought coming from Spicer they would be the u-bolts, and didn't ask till after they came in.
Weeellll, that being the case, I'll go $140 shipped--they will both fit in a USPS Priority Mail flat rate box.
Thanks, Jimbo
are these off the truck? can you get me some measurements? free height and length. flip the spring upside down on a flat surface and measure from the ground to the bottom of the pack. how many leaves in the pack? are there any part numbers I could research? center pin offset to one side? how old or how much use? I don't need the shackles and could pick the springs up or have someone get them for me.
The springs are still in the truck. Think they are 5 plus the overload, maybe only 4. Think the part # wore off, but I can check. IIRC the centerpin is centered, again I can check. I've had the springs before, had a sh!tload of extra leaves trying to get the truck to sit level, but the truck wasn't on the road. Basically sat in the driveway. Sold the springs to a friend, they sat on a shelve till I bought them back. Took the extra leaves but one out, and the truck has been on the road since Oct. but didn't run the springs till a couple months ago. I have another set of the same shackles, they would go with it, but if you don't want them then I can take them off.
Jimbo, might be able to use the yokes, will let yah know what happens.
Also have a full set of cutouts for 88-up trucks. Think they fit Burbs and Blazers too. The bottoms of the front ones are broke, mostly from PO, but did some myself. $150.
I am still interested in these.
They are still on the truck, but gonna try to get the motor/tranny out by this weekend. Once that is out, anything that is usable is coming off. I can get the measurements when they are off. But they center pin is centered, free length obviously won't know till they are off.
can you measure from spring eye to spring eye while they are mounted? that way when you take them off i will know how much they compressed. are they on a pickup, blazer , sub?
They are on the 89, RCLB. Just measured, and it's about 64". Kinda hard to hold one end in the center and see what the tape says...lol
im interested in the 400/203...would you be willing to meet somewere...i would be able to help on some of the gas cost if possible...
Might be able to meet somewhere. If I seperate the two, I think it would fit in my S-10 Blazer. Would have to be the weekend, I can barely get out of the house during the week.....
